1 - 13 of 13 Posts
Hello,
I have a 2008 envoy which all functions stoped working on the drivers door. I found the bad fuse and replaced it and the window went down and smoke started pouring out of the control panel on the drivers door. Until I can get the replacement DDM (drivers door module) what do I jump to rasie the window? Colors and location would be great.
Thanks,
Shawn in Buffalo:confused:
2002 chevy trailblazer_lt_ext
I wonder if you can get it to go up with the passenger door module..
just plug the wires in (the harness that fit it) and see if that works :undecided
:iagree: That's what I had to do when my driver's side panel went out.
Swapped the panels long enough to get the window up then bought a new panel off eBay.
I did use the passenger side module to get the window up, it worked like a champ:woot:-this also confirmed that the driverside module is in fact bad. I called and got a price from the GMC dealer $172.73 :sadcry:for the part and $45.00 to program it as once it's installed it will only control the drivers side and the 3 other doors won't work until it's programmed.
Shawn in Buffalo
2002 olds bravada
Shawn in Buffalo
that is when you start shopping around on ebay :thumbsup:
Calling local dealers for prices like that can only be termed "entertainment." ;)
They could easily have designed that to be otherwise, so they deserve to lose business to Ebay and the recyclers for that evil and customer-unfriendly decision. Lazy engineers probably under management orders to preserve the dealer's undeserved place in the out-year revenue stream.
The Part Is in
FYI- I installed the new part yesterday, nothing works on that panel until it gets programmed @ the Dealer-They get ya coming and going-Bad Design!!
Shawn In Buffalo
1 - 13 of 13 Posts
