1 - 8 of 8 Posts
2007 chevy trailblazer_ss_ls
Hey what's up guys, just joined the forum for the first time. I have a 2007 all-wheel-drive trailblazer SS. Over a few hours time the rear of the truck is all the way down on the bump stops. I got under the truck with soapy water and checked the air bags, airline, and connection at the air compressor and I couldn't find a leak. What do you think I should do next? Does the pump leak internally? Please help! After about 15 seconds of the engine running it fully airs up to drive but I'm unsure if the pump is running constantly while I drive it
Discussion Starter #2
Can somebody please help me out? others must be having the same or similar problem. I'm really worried
How did you check for leaks?
The best way I've found is to spray soapy water on the air connections while it's at ride level. Any leaks, it will show up.
Did this years ago when I was a mechanic, worked every time.
2004 gmc envoy_slt_xuv
Just bought 04 XUV 3 weeks ago. My compressor comes on every now and then, even when I'm driving. I'm assuming that means I have a leak?
1 - 8 of 8 Posts
