81 - 96 of 96 Posts
Same here as the original poster, new-ish 2006 Trailblazer, looking for Build-Sheet and any prior maintenance history. THANKS in advance!
1GNDT13S062224417
hey i think mine was in a front end wreck before i bought it, also can someone run my vin for the options just to be sure it came with what its suposed to?
VIN 1GNDS13S272286440
much appreciated!! :thumbsup:
2006 Build sheet
Could you run a build sheet for my 2006 Trailblazer? It would be much appreciated.
Thank you.
running vin
If anyone is still doing this, could someone please run my vin. Thank you.
VIN: 1GNDT13S972190317
I greatly appreciate any response to this.
Ryan
Hi everyone,
Sorry I haven't been available in a while, life has been hectic.
I no longer work at the dealership, so I don't have access to the GM network.
Sorry, but the well has run dry.
You guys aren't going to get the build sheets. The man doesn't work at the dealership anymore. If you notice there is a sticker in the glove box with a bunch of 3 digit codes cross reference those codes with some of the build sheets or google them or you could always get a carfax or similar. Just trying to help.
RPO List
To any members that bought their Trailvoy at a GM Dealership the Parts Department there would kindly print a RPO Sheet for you. All you others they will do it for you too, just try not to talk too much about Autozone or RockAuto during your visit !!!
GM Vehicle Inquiry System
Summary
VIN : 1GNDS13S242437319
VEHICLE INFORMATION
Merchandising Model : CS15506 -2004 TRAILBLAZER LS 2WD Warranty Start Date : 07/13/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : JAKE SWEENEY CHEVROLET, MAZDA, BMW
33 W KEMPER RD
CINCINNATI , OH 45246-2536
(513) 782-2800
Selling Source : 13 - CHEVROLET
Site Code : 09596
Business Associate Code : 112838
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 07/13/2004 7 miles 07/13/2007 36007 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/13/2004 7 miles 07/13/2010 100007 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/13/2004 7 miles 07/13/2012 80007 miles
36/36000 FEDERAL EMISSION 07/13/2004 7 miles 07/13/2007 36007 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/13/2007 191548 # J3480 - WATER PUMP REPLACEMENT 40870 miles
02/23/2007 876855 # E9050 - POWER STEERING PUMP REPLACEMENT 32782 miles
02/23/2007 876855 # F3023 - HOUSING ASSEMBLY, DIFFERENTIAL - REAR DIFFERENTIAL - REPLA 32782 miles
02/23/2007 876855 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 32782 miles
02/23/2007 876855 # L1197 - FUEL LEVEL SENSOR REPLACEMENT 32782 miles
02/23/2007 876855 # Z7903 - 3-DAY COURTESY TRANSPORTATION 32782 miles
02/23/2007 876855 # E0605 - SPARE WHEEL HOIST REPLACEMENT 32782 miles
06/14/2004 A37319 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Vehicle Build
VIN 1GNDS13S242437319
VEHICLE BUILD
Gross Vehicle Weight Rating : 2520 kg (5557 lb) Order Number : HFWSZM
Build Date : 06/14/2004 Build Plant : 14206
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AJ1 - DEEP TINTED GLASS AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG
AM9 - SPLIT FOLDING REAR SEAT BACK AR9 - FRT BUCKET SEAT, DELUXE
AU0 - KEYLESS REMOTE DOOR LOCK AXP - MPV VIN IDENT POSITION
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FLOOR MATS, FRONT AND REAR
B33 - REAR COLOR KEYED FLOOR MATS B84 - BODY SIDE MOLDINGS
CJ3 - CLIMATE CONTROL C4D - GVW RATING - 5550 LBS
C49 - ELECTRIC REAR WINDOW DEFOGGER DAY - ASSEMBLY PLANT MORAINE, OHIO
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER EVA - EVAP EMISSION REQUIREMENT
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
G80 - LOCKING DIFFERENTIAL JF8 - BRAKE VAC POWER, 4 WHL DISC
JJB - PT DRESS SUBASSY NOT INSTALLED KG4 - GENERATOR 150 AMP
K18 - ELECTRIC AIR INJECTION SYSTEM K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
LL8 - VORTEC 4200 SFI I6 M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NT7 - EMISSION SYS FED - TIER 2 NZ3 - FULL SIZE SPARE
N40 - POWER STEERING PDC - SEAT, 8-WAY POWER DRIVER
QC3 - ALUMINUM WHEELS QRF - P245/70R16 FOUR ALL-SEASON WOL TIRES - EXCLUDES SPARE
R6B - PROC CODE, ONSTAR NOT FORCED R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS TB4 - LIFTGATE
T61 - DAYTIME RUNNING LIGHTS T98 - STAMPING VEHICLE IDENT NUMBER
UA6 - THEFT DETERRENT ALARM SYSTEM UB0 - AM/FM STEREO W/CD
UY7 - TRAILER WIRING HARNESS U73 - FIXED MAST ANTENNA
VK3 - FRONT LICENSE PLATE BRACKET VXS - COMPLETE VEHICLE LABEL
V1K - LUGGAGE RACK CROSS-BARS V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
X88 - CHEVROLET CONVERSION YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID PAINT
1SB - LS PREFERRED EQUIPMENT GROUP 2 * POWER MIRRORS, HEATED * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS * CRUISE CONTROL * BODY SIDE MOLDING * LUGGAGE RACK CROSS-BARS * TRAILER WIRING CONNECTOR * REMOTE KEYLESS ENTRY * THEFT DETERRENT SYSTEM
1SZ - PREFERRED EQUIPMENT SAVINGS
50U - SUMMIT WHITE 6HN - SPRING
7HM - FRONT SPRING 8EU - COMP RR LH COMPUTER SEL SUSP
9EU - COMP RR RH COMPUTER SEL SUSP 95H - MEDIUM PEWTER
95I - MED PEWTER/DK PEWTER INT TRIM
Would you look up my 06 Trailblazer EXT LS
Vin# 1GNDS13S362299003
Vehicle Guide Please??? I have added the following deep tinting windows, double din stereo with listened plate back up camera, changed tire size from 16's to 245 70R 17's but have 2003 17" wheels, but would like to find good used factory 06 Trailblazer EXT wheel if anyone should know where might find prefer close to Bowling Green KY or just across Tennessee state line....It just has roller over to 119,000 cause I was hurt on Job in GA and have been drawing disability since 1999 is why doesn't have more miles...
Also if can be done even though. Is 2003 Dodge Ram 1500 SLT single cab 8 ft bed.. I am curious what is said about it ok here's Vin # 1D7HA16N73J523254 Thank you very much......
Don't thank Jim Johnson Nissan would for me lol..... Was it told when I bought mine in 2008 which is 2006 model number hat mine was a lease vehicle only had 34,000 which was a little more than even 34 thousand.... But had one accident to front bumper cover, hood, headlight, and driver-side fender.... On of course 06 Trailblazer EXT LS but have had water pump, recently driver-side inner and outer ball joints and just inner on passenger side... Over all still runs and rides good is why having trouble parting with it just yet....
can anyone run me an RPO and build sheet please?
06 trailblazer ls 4wd
1GNDT13S262120687
Thanx in advance
-=Fred=-
2004 Trailblazer LS 4x4, 4.2L:, 2016 ATS-V, 2014 CTS-V Wagon, 2018 Audi A7
Have you looked in your glove box? Is there a sticker on the glove box door? That is a list of the RPO codes for your truck.
2002 TrailBlazer LS with all the usual stuff...
Hi everyone,
As dwright406 mentioned, he's not at the dealership, so that particular avenue is closed. Perhaps a quick trip to the local Chevy/GMC dealer might work...
Thanx guys, I am doing an aftermarket stereo install and I do believe I have a bose but was hoping to find the radio RPO.
no biggie
Regards
-=Fred=-
RPO is on the sticker on your glove box door
From a list I found at another site (and matched against my own RPO sticker), these are the radio options, not including the various packages they might be a part of. Or including Onstar. There might be more but these are at least a start.
UB0 - AM/FM Radio, CD Player
UC6 - AM/FM Radio, RDS, 6-Disc Changer, Auto Tone Control, and ETR
UN0 - AM/FM Stereo w/CD Player
UP0 - AM/FM Stereo w/Cassette and CD Player
UQA - Bose Premium Sound System
81 - 96 of 96 Posts
