1 - 1 of 1 Posts
2006 gmc envoy_denali
Ok, I know that there has been probably a thousand questions about noises in the front end of a TrailVoy, but I have one neither I nor my mechanic can find the answer to and I need help.
FYI - 2006 GMC Envoy Denali (5.3L V8) with 39,000 miles and relatively new (~2,000 miles) Michelin® LTX™ M/S tires
The noise or "chirp" sounds as if it is coming from the front passenger side of the vehicle and ONLY under the following conditions:
-Any speed, the noise is the same intensity and I cannot pinpoint a pattern
-A crosswind must occur across the passenger to driver side of the vehicle (this is key)
-When the brakes are applied, coasting, or accelerating.
-Turning or not
-When a crosswind is occurring the noise does sound suspension related, i.e. it occurs over bumps.
I have tried taking the passenger tire off of the vehicle and greasing (white lighting grease) everything under the sun. I have not replaced any parts, neither has my mechanic; however, he has twice greased the control arm bushings and his guess may be the shocks. I personally have tried greasing the hood latch, arms, and rubber bumpers.
Any ideas would be appreciated.
Thanks.
1 - 1 of 1 Posts
