1 - 1 of 1 Posts
2006 gmc envoy_sle
I have a 2006 Envoy and I was stuck in "4WD" but only the front differential was locked and my transfer case was in 2WD. I replaced my transfer case motor and in doing so my bolts wouldn't line up and I tried shifting the transfer case using the motor and something bound up in the case and a lot of grinding happened. Currently the case is in 2WD and I can drive with no issues but my maintenance light is on (I believe it's because the motor is not on the case) and my selector switch will not light up indicating I'm in 2WD. I also have a check engine code U1026 which says that there is a communication error with the case.
I'm sorry if this is confusing in any way, this is my first post and I'm not sure how this site works and how people will respond to questions like this.
1 - 1 of 1 Posts
