1 - 3 of 3 Posts
Just bought a 2006 (4x2) TB w/4.2 engine knock...acquired for 5.3 conversion. The 5.3 is a low mileage 2004 that I've had for years. I've installed a 2004 Z06 (308) cam, 4x cam drive and 58x reluctor. The transmission I will use is a 6L80e. I have a set of headers for a late Camaro that I hope will work (any thoughts).
Spent the morning at local U-Pull yard and got the 8 pieces for the factory engine mounts, wire harness, fuse box and few other parts. Hoped to get an a/c hose for the V-8 but it had rear a/c and someone had already cut it. (Near heat exhaustion due to Central Florida heat/humidity.):mad:
This should give me a good starting point w/factory motor mounts and wiring.
Goals of project is for a reliable daily driver with some towing capacity and good fuel economy.
I doubt the computer in the TB will run a 6l80.
ECM
You are correct, sort of, the 6L80e has the T43 controller built in; I have other E67 controllers and HP Tuners to 'marry' the two. We'll see how it works out. Thanks for the input. :)
1 - 3 of 3 Posts
