Well it’s been a while and I am finally finding the time to get back at it. I am slowly learning more and more about DC circuits. I will use this post to document my findings as I go in the hopes it may help someone else or someone may chime in to help! Any and all advice is greatly appreciated.
So I managed to get the plastic off around the ignition cylinder in order to check out the passlock sensor connector. Some videos I watched claimed a common problem of the connector having a little too much wiggle room and causing issues from vibrations or weather. I don’t think this is my issue, while the connector can wiggle a tiny bit, wiggling it while the car was on didn’t seem to cause any changes.
Now I am moving on to checking power going into the BCM via orange wire from TBC 1 Fuse #31 -> BCM connector C1 Pin A3.
I also will check power leaving the BCM on red/white wire going to the ignition from BCM connector C2 Pin E9.
I pulled out every fuse and they all look good. I did a resistance check on a few fuses that seemed relevant and also checked resistance on the circuit breakers.. everything seemed to check out. EDIT: Also I checked the Starter relay and a couple other relays out with just a resistance check between the 86 and 85. I don't have a spare battery to hook them up to really check them out but i think they are OK.
Here is my plan:
Troubleshooting #1
Check continuity of orange wire powering BCM
1. Disconnect car battery
2. Cut orange wire before it enters into BCM at C1 Pin A3.
4. Set multimeter to 200 ohms
5. Connect one lead to ground
6. Connect other lead to orange wire
Should be less than 5 ohms of resistance
Troubleshooting #2
Check ground of Black wire leaving BCM
2. Cut black wire after it leaves BCM at connector C2 Pin E8.
3. Set multimeter to 200 ohms
4. Connect one lead to ground
5. Connect other lead to black wire thats going to ground
Troubleshooting #3
Check continuity of red/white wire leaving the BCM -> Ignition/passlock sensor
2. Cut red/white wire after it leaves BCM at connect C2 Pin E9
5. Connect other lead to red/white wire that supplies power to ignition/passlock sensor.
QUESTIONS
1. Where does the BCM ground out to and/or can I check resistance through the BCM? Meaning if I disconnect car battery and set multimeter to 200 ohms, put one lead to a good ground and the other lead to the orange wire going into the BCM, can i check the resistance of this wire going into the BCM and then eventually to ground or will this mess up the BCM?
Also I drew up a diagram of the Bypass Module I installed and relevant circuit. Also the directions I was given for the install of the bypass mod.. Hopefully I got it all right.
Thank you!
EDIT: Curiosity I have noticed on very rare occasions... I will be driving down the road listening to music and the music will suddenly slow down for a few seconds.. then jump back up to normal speed. I'm curious if this is a voltage thing to the radio? This is by no means a regular occurrence but i have noticed it happen maybe 3-5 times over the year. I drive my vehicle nearly every day. Thought I should include this as a honorable mention considering I may be having some type of power issue.
