1st off I'm new to the forum and have seen a lot of great info from people so thanks in advance.
I have a 2005 TB that I installed an aftermarket radio in. I didn't buy the (RAT/RAD) connector and just used a basic adapter from WM. Everything worked ok until I need to find a place for the accessory wire which after reading a few places I could use the brown wire on the top right of the wiring harness under the steering column. Radio worked fine and still does but about 2 days after install I notice my TB running rough and get progressively worse. Really felt like a clogged cat or similar issue but could tell huge difference in loss of HP. It got to the the point to where it would barely pull a hill before it quit entirely. On my way home the other day when I turned from a stop as I gave it gas it would hardly go at all until it completely wouldn't move. If I turn the ignition off and back on it idles fine and will move 30-50 yards before there is no response. I unplugged the positive and touched it to the negative for 30 seconds pulled both PCM fuses 28 and 10(I believe 10 is correct) for 30 minutes and plugged it back in hooked up battery and same results. Also since I've had it it has been throwing code P0140 (O2 issue) and right before it stalled out completely it gave me P0756 and P0130 for the 1st time.
Worried I may have fried a PCM/ECM/BCM or something worse. Really don't know where to start. Any and all recommendations appreciated
