1 - 1 of 1 Posts
Looking for help solving a washer pump problem. The windshield washer pump runs nonstop even when the key is in the off position. I already swapped relays so that is not the problem. For now I pulled the fuse. Some how the coil inside the relay has 12v to it which then pulls in the contacts to run the pump. All this happens with the ignition off. Any suggestions?
Thanks.
1 - 1 of 1 Posts
