Hello, Please help. I have a 2004 TB and shifter button won't click to lock into place. Able to shift without having to push it and step on brake. Also, key is unable to be removed from ignition as the key won't turn back due to this. I have to disconnect battery everytime I park or the power remains on. Any suggestions would be greatly appreciated!!!!
fix?
Were you able to find the problem. Mine 02 envoy does has the same problem. I've replaced the shift interlock and ignition switch but still have same problem.
Grrrrr
This just started to happen on mine Monday. I don't remember if it still has my old '02 listed but I'm now driving a '07 TB. I'm worried about shorting the system or stripping the lug/ battery when disconnecting reconnecting the battery. Anyone fix this issue? Mine does not click when I step on the brake I can just pop it into reverse n' go! Part numbers or names of potential parts so I can price then out would be greatly appreciated!! Thanks guys!
