If you slowed down a little bit and ran a search on "P0014" - the exact error code, you should have found this thread:
http://forums.trailvoy.com/showthread.php?t=53997
Welcome!
Oh, how long has it been since you changed the oil? A sludge build-up on the screens of that sensor can also cause that code, and the fix is a lot cheaper than replacing the sensor.
We also have a tradition of posting the responses here rather than emailing to the original poster, since then they can be searched and benefit others in the future. Taking the answer by email and running just isn't in the spirit of the trailvoy community.
Roadie beat me to the punch! I go to type in the response and his is already there.:cry: It should be right on the front of the engine, to the right of the upper radiator hose. There is also a camshaft position actuator solenoid right behind the power steering reservoir so make sure you know which one needs to be replaced.
