My 02 Trailblazer LS lost low beams last week, right after jump starting a guy with my car running. High beams are good. I checked underhood low beam fuses 3+6, swapped relays 45+46 (even tried a new one) and checked all the fuses in driver side 2nd row underseat fuse block: 4, 7, 32, 40, 50, 52. All are good and low beams are still out.
Anything else to try other than thinking that both low beam bulbs somehow burned out simultaneously? Thanks... :undecided
Same here... Mines just went out lastnight while i was driving.. I have done everything you have done and they are still out.. Please keep me posted if you figure it out
Same thing happened to me 2 weeks ago. I just got around to looking at them yesterday. I pulled all the fuses, bulbs, relays and couldn't find anything wrong. Mine is also a 2002 LS. I noticed this thread was marked as "Solved" yet I don't see the reply to what is wrong. Have you two guys figured out what's up with the low beams as of yet?
This is always my 1st go to for answers on my Trailblazer. I just googled the problem and it seems to be the #46 relay. I'm going to swap #45 with #46 and see if that helps, then order a new one if that is indeed the problem. I'm sure it is.
I just had the same problem with our 2005 Envoy. Checked the underhood fuses and they were good, swapped the relays and no change, checked the bulbs and one was burned out but other was good. It shouldn't effect both sides though as I've had one side burn out before and the other side still lit up.
Hey bud, check out gmt nation .com the guys there will help you. No one here is going to be of much use unless it's someone from gmtn where the experts now reside. I hope to see you there! :tiphat
Related Threads
1.3M posts
173.5K members
Since 2004
