1 - 1 of 1 Posts
gmc envoy_sle
SAVE YOUR 2002/2009 TRAILBLAZER or ENVOY from the junk yard Many of these SUVs suffer from rear upper trailing arm frame rust/rot (See actual photos) Especially in the northern regions of the country I was a victim myself After searching I found that no one had a replacement mount for these vehicles My local frame shop wanted $3000 to repair my rear upper trailing arm mounts I designed these and had my local body shop weld them on for 50% less Offered is a solution to that problem Why buy a KIT when you can get an actual part These trailing arm mounts are constructed of high quality plate steel with 12 gauge steel housing complete with brackets for E Brake & Brake line block with all brand new mounting bolts and eliminates cage nut in frame Again why buy parts and have them assembled when you can use these from box to vehicle Mulitple sets available
Installation will require welding to fasten to frame rail by a professional
These are $250 a pair + Shipping Allow 5 to 10 business days after ordering if not in stock
No warranty intended or expressed These are not an OEM part
Contact me with any questions [email protected]
Thanks for your interest
1 - 1 of 1 Posts
