2006 chevy trailblazer_ls_ext
Ok so i went down to discount tire this morning to have my new wheels and tires put on. I purchased the 16x8 MB Rockers like 2005tblaze and 265/75/16 Goodyear TD's. They mounted them on my TB ext 4wd and the were hitting my calipers. HURT ME! the car would not roll. I was bummed!!!:no:http://forums.trailvoy.com/images/smilies/no.gif
I had been waiting for this day for sometime now. sucks!
you need 17's minimum to clear the front Calipers on the long wheel-based versions of the Trailvoy
reason being is that the rotors are almost an inch bigger in diameter in the front than the short wheel-based versions
Yup, you sure do.......16s also don't fit the SS guys either for the same reason, the rotors are an inch bigger and will not fit.
Now, there is a way to make them fit, but I would not recommend it. You can use the SWB caliper brackets and smaller SWB rotors, which would allow 16s to fit, BUT you reduce the braking capacity a bit......with the extra weight, I wouldn't do it, but it would allow them to fit.
