1 - 6 of 6 Posts
Hey everyone, I was installing a power amp for a subwoofer today in a 2003 Trailblzer LS. Im using the stock radio and the only problem i ran into was finding a place for the remote turn on wire. Cant use the cigarette lighters because they are always on. Is there another 12v pick up that turns on and off with the ignition that i can splice into anywhere, or does anyone know of a better way to go about doing this?
Thank you
I tapped my wire into the ignition fuse. You can also use the brake fuse. It turns the amp on only when in ON position, not in ACC
1 - 6 of 6 Posts
