1 - 1 of 1 Posts
Hello,
2006 Trailblazer LS I6 4x4
I know this issue has been posted before but different question on the fix. The left turn signal doesn't work. The right works. When I push the hazards the left doesn't work either.
After researching it seems to be a typical problem, usually either the signal switch or the flasher module.
I saw the "solved" post on the '07 envoy or blazer. But that flasher module says its not the same part for my '06
Any thoughts on which part I do need?
Thank you.
1 - 1 of 1 Posts
