Hey! I’m new here and hoping someone can help! I have an 05 trailblazer EXT 4.2L 4x4. I’ve been having ac problems since I got it. At one point I swapped a fuse and it worked perfectly until the compressor gave out. For some reason at the time the fuse kept blowing. As of this week, I change the ac compressor, drier (accumulator), low pressure switch, orifise tube, relays and fuses, vacuumed the system and recharged it twice, and STILL ac is not working. When I first changed it, the compressor would kick on for about 15seconds and would shut off. It wouldn’t engage until the vehicle was restarted. So far I haven’t found any leaks, and I jumped the compressor straight to make sure it was working correctly and it was. I had jumped the connection to the pressure switch before I swapped it and it would engage, but now when I do it, nothing happens. The condenser looks okay, no bends or leaking fluid, but I’m assuming it may be clogged. When I swapped the orifise tube it was full of shredded metal. Is it possible that a clogged condenser would cause the clutch not to engage? Any help is much appreciated! Also quick side note, for some reason the rear air and passenger air comes colder faster, and the driver side would not come very cold at all prior to me swapping the compressor.
