2004 chevy trailblazer_ls_ext
I have an 04 trailblazer with the 4.2l, giving me absolute fits. For some reason, it randomly stalls at stop lights when the A/c or heat is all the way on. it usually acts like a slow stall, the RPMs drop way low, then quits, but then it starts right back up after i put it in neutral or park.
I have checked the Alternator, and sprayed for vacuum leaks, done plugs and coil packs, but i am not quite sure where to go from here. it is not throwing a check engine light so my computer wont help any...
Any help would be awesome.
2008 isuzu ascender
Pull the throttle body off and thoroughly clean "both" sides of the throttle plate . Reset the pcm by pulling the fuses for 30 minutes .
so i did that as part of the spark plugs and coil packs thinking that it was standard procedure. should i do it again?
I've had the same issue for as long as I've had mine (approx 3 yrs 30K miles. it has 181K on it now) when a/c or defrost is on ... heat is ok. My solution (unfortunately) is to turn off the ac/defrost while I'm stopped. Crude, and a nuisance, but it works.:rolleyes:
