Hello Everyone!
I am having a nightmare with my 2003 Chevy Trailblazer. Here is the history of the current repair so I can get some advice from you FINE GENTS hopefully.
OK, so I had the fuel pump bust a sending line the other day which dumped all the gas out and noticed it in a parking lot where it finally ran outta gas just as I was about to turn it off (idling).
So I replaced the fuel pump with a new one from advanced auto (Aftermarket) and then when I started it there was a slight knocking sound coming from the vehicle. I traced the sound and it didnt really seem to be coming from motor but instead from the exhaust and there was no physical pounding vibration being put out from the knocking through the motor I could feel with my hand. Then I was getting a P0300 or random misfire...so I drove it for a few miles and it finally registered a P0306 or cylinder 6 misfire. So, I swapped the ignition coils and spark plug from cylinder 6 to cylinder 2 and drove a min and the misfire migrated to cylinder 2.
I replaced the ignition coil and spark plug on the now misfiring cylinder #2 and no more misfire! So, I figured it was just happenstance that had a ignition coil went at same time as the fuel pump.
Well...then I drove the car about 30 miles after this repair and noticed a reduction in power gradually and at same time the SES light came on now kicking out a P0172 code or SYSTEM TOO RICH (Bank 1).
Figuring the system was just catching up I reset the code and carried on, well got halfway home from family on christmas and lost almost all power on highway dropping down to about 20 mph on expressway and had to take back roads home rest of the way. Basically it didnt have enough power to maintain speed above 30mph and if u lightly touched the gas it would speed up, but if you went any more then lightly feathering the gas pedal it would bog down and loose speed.
I drove next day and seems like it is running better when cold and when it warms up it looses even more power and runs even worse.
Freeze Frame INFO Data:
Calc Load% 95.7%
ECT(c) 91
STFT B1% 0.0
LTFT B1% -11.7
MAP(kPa) 74
Eng RPM 1461
Veh Speed (km/h) 7
fuel sys CL
Concerning Live Data Info
02S B1 S1(V) .765
STFT B1 S1(%) -19.5
O2S B1 S2(V) .785
STFT B1 S2(%) 99.2 <------ (This Seems Wrong To ME) ???
Also running LTFT numbers are regularly showing anywere from -5 to -15 or so while under load while STFT are holding steady between +5 - -5 depending on loads while runing. but LTFT seems to always go into the -15 or so anytime load is put on...NEVER to POSITIVE numbers side.
My concern is that all this is happening right after installing this new fuel pump...I dont wanna keep chasing down problems if the fuel pump has something wrong with it and seems odd that all this happens after I swaped out the fuel pump but not before...However, the vehicle did run outta gas at a stop and this might have had an effect on the systems.
Please, any advice will be hugely appreciated and I WILL CHECK this forum regularly for any questions or updates any places here.
Thanks.
Brad!
Calc Load% 95.7%
ECT(c) 91
STFT B1% 0.0
LTFT B1% -11.7
MAP(kPa) 74
Eng RPM 1461
Veh Speed (km/h) 7
fuel sys CL
02S B1 S1(V) .765
STFT B1 S1(%) -19.5
O2S B1 S2(V) .785
Thanks.
Brad!
