Again, Good Luck!
No need to use a pressure Guage just remove the upstream o2 sensor and then drive to see if the power is better. Will be loud but won't hurt anythingHello! New here... Just got an 03 Trailblazer 4.2 with 212k miles on it with some sluggish acceleration. I need to replace the VVT solenoid (have it being delivered tomorrow) but I am not sure if that will still fix the issue. If I do replace the solenoid and its still sluggish, what are other issues that can cause this issue? Ive seen reports of like a clogged Cat Conv but I think it may be transmission related (such as the torque converter) because it has a hard time with hills and then also it has an issue changing gears... Any suggestions would be appreciated!!!
Ill try this once I can get my hands on an O2 sensor socket...No need to use a pressure Guage just remove the upstream o2 sensor and then drive to see if the power is better. Will be loud but won't hurt anything
I am no fan of Ravalli's "make a joke of everything" attitude, to the point I hate reading his responses. But I do because once you get past his attempts at humor when most need advice, not jokes, his advice is 99.9% spot on.Yeah I already priced the ignition coil from Rock Auto... will order it tomorrow after work... Also Ravalli, Its kind of hard to trust the advise from someone who suggested to drill a hole in my muffler/cat converter...
I am on other forums where I'm not the only one advocating for full flushes on 4L60Es, there's nothing special about the ones they put into Trailblazers. Have fun being a hack if you think it's cool to keep 20 year old fluid in your transmission. Does that logic work for the engine? Brakes? Cooling system? Power steering system? Axles? Transfer case? Or does old, nasty fluid cause issues there too? Or do you just ignore it?I am no fan of Ravalli's "make a joke of everything" attitude, to the point I hate reading his responses. But I do because once you get past his attempts at humor when most need advice, not jokes, his advice is 99.9% spot on.
Superchrged111 is the ONLY person on these forums who advocates a full trans. flush. The ONLY one.
Take that as you will.
I havent been able to remove and test drive with upstream O2 out but I also havent driven enough for the codes to repopulate for anything yet. I have to drive to and from work tomorrow so hopefully that will be enough finally to make it populate an error report for meGreaseGirl95, what DTCs are now present? Did the P0014 and P1345 go away or are they still present?
In my earlier response I suggested you unplug the O2 sensor. I meant to type that you remove the upstream O2 sensor and then go for a test drive as others have suggested.
Thanks and Good Luck!
Logic also includes real world experience. I used to be like you. Ignoring other people's practical experience just to fit my own narrative. I lost a lot of races because of that. Sometimes, right just doesn't make sense, but it doesn't make it less right.I am on other forums where I'm not the only one advocating for full flushes on 4L60Es, there's nothing special about the ones they put into Trailblazers. Have fun being a hack if you think it's cool to keep 20 year old fluid in your transmission. Does that logic work for the engine? Brakes? Cooling system? Power steering system? Axles? Transfer case? Or does old, nasty fluid cause issues there too? Or do you just ignore it?
