1 - 3 of 3 Posts
All doors but drivers word with key fob. On drivers door when outside to open I have to hold key to unlock for handle to work. Inside I have to hold the unlock button above the handle over to open the door??? Actuator?
Thanks
Just had my driver door apart again, as my tumbler to actuator link is in dismay, I can only get in with my FOB which is scary being keyless entry. After removing the panel, you can get a couple different views of whats going on in the door, if things are still together in there linkage-wise, (rods are metal, clips are plastic) it may be the actuator. In the actuator itself there are a couple tricky plastic linkages that do physically connect to the rest of the setup. My guess is the driver door gets shut/slammed the most and this stuff is fragile! I found multi packs of the rod-end "clips" at the local parts store, and there is a couple Ok vids on YT around this issue. Just protect your forearm somehow as mine is torn to heck from battling the akward positions.
I'm on my way to "Pull-A-Part and pull one apart o_O. Since all the rods seem to be working, I hope it's the act.
1 - 3 of 3 Posts
