03 EXT Tailgate onto 05 EXT body.
507 Views 5 Replies 3 Participants Last post by  Denali94
4
Hey guys,
The rust got to my original Hatch
Hood Automotive tire Automotive lighting Wood Rectangle
And all I could get a hold of was Black tail gate from an 2003 ext at the local junk yard.
The only problem is that it won't fully close to where it latches with the support struts attached.
Tent Plant Motor vehicle Hood Tarpaulin
Automotive tail & brake light Car Vehicle Plant Automotive lighting
Automotive parking light Car Vehicle Automotive tail & brake light Land vehicle
I was told the liftgate was interchangeable.
Am I doing something wrong?
1 - 6 of 6 Posts
Maybe the hinges are a bit different ?
They look the same, and there's no way to adjust how the hatch is mounted.
Everything lines up like it's supposed to when I take the support struts completely off, but man is that liftgate heavy😓 without them
I checked a couple of parts places and the struts are supposedly the same for the '03 and '05 but that does not mean that the mounting points are exactly the same between the model years.
Yeah, it seems like they would be the same but it is possible that while the mounts could be the same distance apart from year to year, the actual locations might be higher or lower relative to each other. If you are mixing a higher mount location on the car or a lower location on the lift gate your strut will appear to be too long and may give you the symptoms you are experiencing. . Since the problem only shows up when the struts are installed it sounds like a strut mounting point issue?????
That has to be the issue, it's the only thing that makes sense. Thanks for all your help!
Let us know what you learn. You can probably find a "shorter" strut that will fit the space you have. That door is darned heavy ! ! !
1 - 6 of 6 Posts
