ok to start this is my first post on any forum ever so forgive me if im doing things wrong...i read trailvoy all the time tho you guys are great thanks for all the help in the past...but to no avail i cannot find anything or anyone with my similar problem.
one morning we got into our envoy(2003 xl slt 5.3 v8) and after turning out of the driveway both tires turned away from each other almost like being toed out going in opposite directions limped it home and tried to adjust tie rods to get it back straight again. tried driving again (slow and in the next door church parking lot) was fine then tried to turn right sharply and then drivers tire toed out and passenger stayed straight. re aligned again basically goin back in the direction i just took it out from. backed it out of the garage and both tires toed out again as they did the first time after about 2 feet. Jacked up one side and i could turn the lifted tire freely from the other which didnt move but steering wheel bounced back and forth like crazy. Uncle said rack was shot which made sense to me.
Replaced rack with a good used one did ball joints, upper control arms at the same time took it in for an aligment and was all good for about a week.
driving to work my jeep broke down and wife was on her way to rescue poor old me. shes call about half way to me and says she hit a bump going about 55mph and the wheel went crazy and the tires were pointed out again.:bonk:
now it drives straight just fine but when breaking hard right before it comes to a stop wheels toe out away from each other and wheel jerks around as it happens....pop it into reverse and it straightens itself out and drives fine except the wheel is in a different place each time and the tires are getting chewed up bad(we only drive it very short distances when need be while we saved up for more parts)...brand new rack and pinion just came in this morning and plan to start it tonight after work and im also doing the sway bar bushings and links then another alignment and more tires...
My question is has anybody ever heard of this before and is it something else that is causing the rack to go bad...im hoping that the used rack i got was bad as well and this will be the end of this nightmare...because i will drive it into a lake if not..lol...not really..oh and no neither rack leaked at all and pump seems fine..thinking about flushing the system out while i have it torn apart too
again sorry if this is done wrong and thanks to anyone who can help
