2003 gmc envoy_sle
With key in Run position only battery light comes on. After 5- 30 minutes the rest of panel lights come on and it starts. Done this for a couple months. Changed ignition switch and still does the same.
Primary voltage failure - either ground or battery --- somewhere....
Go 'wiggle test' all the heavy wires from B- battery to engine ground and B+ power to the power dist panel.
Video pending for you and a change of wording from me.... BRB.....
2003 gmc envoy_sle
Discussion Starter #5
Did clean all gronds and positive wires this afternoon, Still the same. If I disconnect batt for about an hour it starts right up. If our part store has relay in, I'll try changing it.... and pray :) Thanks
