1 - 7 of 7 Posts
Hey guys
I've had this issue for about 6 months and it's starting to bother me. I've got a 2002 Trailblazer LS and the passenger-side window and lock just completely stopped working. The driver's switch doesn't work either. When you press the switch on either side for the window, you don't hear anything.
I don't have much experience with car electronics, but I was thinking this is most likely a power issue, but I can't be sure. Any advice on where to start would be very much appreciated.
Thanks!
Discussion Starter · #2 ·
Just thought I'd update my progress.
I narrowed it down to the power window/lock switch cluster. I removed the driver's side and hooked it up to the broken passenger's side and it controlled the window and door locks perfectly fine.
Does anyone know of a supplier of OEM GM parts in Canada? or that ship to Canada?
Thanks again
2002 chevy trailblazer_lt_ext
When mine went out, I purchased an used one off ebay for $40. It doesn't matter if the trim plate matches your interior, the module pops out of the trim panel so just re-use the original one.
1 - 7 of 7 Posts
