We replaced the intake and valve cover gaskets at the sametime we replaced the VVT Solenoid and Camshaft position sensor the computer was properly unplugged from the battery and was properly handled and not damage during repairs when we finished all the repairs and went to start it it goes through all the key functions but when you try to crank it does nothing not a click or nothing the battery was fully charged what could have happend during the repairs that would cause this everything was done properly
Maybe a bad ground hot wire to starter?
Like maybe it got pulled a little to hard while trying to remove intake manifold through my wiring harness? How would i test this with out undoing all the work i just did to see the wires coming off the starter? Because that starter is in a hard to reach place my hands barely fit in that area with everything bolted back up
2003 chevy trailblazer_ltz
Do you have power to the "S" terminal of the starter motor when the key is turned to "Crank"?
