Are there any videos or a how to list to change this out with a new one?
2002 Trailblazer LS.
Thanks in advance
Thanks in advance
i replaced my throttle body and it still not working now it says its the internal control module position how do i fix thatThere are no replaceable throttle body sensors of any kind on a 2002 with the 4.2 L engine. If the throttle position sensor or idle air control valve goes bad, the entire throttle body is replaced.
po60e code 4.2 motor the cheapest brand on throttle bodyWelcome to the Forum!
First off, what caused you to replace the throttle body? Second, what OBDII diagnostic codes are present. Third, which engine are you working on, and finally, make sure all the electrical connections are seated properly.
One more thing - what brand of throttle body did you purchase?
Cheapest .. uh huh.po60e code 4.2 motor the cheapest brand on throttle body
