1 - 3 of 3 Posts
Does anyone here know how many ground wire connections there are to the frame on a 2002 Envoy?
2004 gmc envoy_slt_xuv
My schematics only show (2) maybe (3) grounds directly to the Frame:
G106 - From Battery to Eng Side of Left Front Wheel Well (might be connected to Frame?)
G304 - Left Frame Rail near ABS Pump
G305 - Left Frame Rail near Fuel Pump
You did not specify the reason for your question or if you had an issue.
There are many more Grounds connected to the Body, but I could not find, and I'm not even sure if there exists a Ground strap between the Frame and the Body. Most vehicles have at least one.
I have the info for all of the Grounds so let me know if you need more.
module issues
Thank you bromanjr for the response.
Read about issues here.
After going through everything here I spoke to the body shop that did the work on the envoy and they want to start with the basics, such as the grounds to the frame. They don't think any other grounds were disconnected in the process.
The person that did the frame swap thought there was two ground connections to the frame and wanted me to check to be sure. I didn't want to muddle the other post.
Thanks again.
1 - 3 of 3 Posts
